CD079
- Jan 1, 2023
- 11
- 19
- Phoenix
- ‘23 F150 Tremor Antimatter Blue Delivery ETA 2 weeks
It’s been a while since I’ve wired anything to a vehicle. I currently have four LED pod lights that I’m installing on each side of the hood, two on each side. Inner lights pointing forward, outside lights pointing off to the side.
Each light has two wires, a red and black. My understanding is that I’ll run the black wires to each of the two upfitter wires by the battery, and then run the red wires to a ground point under the hood. This way I’ll have control of whether the inner or outer lights are on, right? I can run the two inner light black wires to say aux 1, and then the two outer light black wires to aux 2. Then combine all four red wires, crimp them inside a ring terminal and put that on a ground point. I feel as though it’s not as complicated as I’m making it, but want to be sure. Everything I’ve wired prior to having this Tremor has been a wire to either battery and ground, or add a fuse and ground, like my dashcam.
