Filbie
- Apr 10, 2026
- 7
- 14
- Atlanta area
- 2026 F150 Tremor 5.0
- Current Ride #2
- 2024 Bronco Raptor
If you pull the battery out, you can pull and gain much more access to the wires. Makes life much easier! A little more insight if someone stumbles upon this, the bundle wrapped in the engine bay with red tape is hot. The white tape bundle is to connect to the red and then tap in equipment inside the cab.Amber DRLs installed, definitely was not expecting the upfitter hunt. Easy install other than the 30 minutes searching the internet and trying to find the location plus 3 attempts to crimp a butt splice.
On the BRaptor they are easy access right behind the driver firewall. smh as to why they are located behind the battery and is copper really that expensive that you couldn't make the wires 3" longer?
