- Mar 4, 2022
- 929
- 1,825
- Jupiter
- ‘21 Leadfoot Grey 402A Tremor
Featured
- #1
In Collaboration with @beo_tom , would there be interest in a plug n' Play harness for the upfitters? This harness would easily tie into the 6 upfitter wires provided from the Factory and convert those 6 wires into 6 x 2 pin(power and ground) water proof deutch connectors.
Pricing for the harness would be $100 plus shipping
Tools required for install:
Wire strippers to expose wire on factory upfitter wiring
Heat gun/hair dryer/lighter to shrink shrink tubing
adjustable wrench to install ground leads onto Battery negative terminal
The harness would come with solder shrink waterproof butt connectors already installed on the upfitter leads. User would only need a heat gun/lighter to shrink the other side down on to the upfitter wires from the truck and melt the solder to securely splice the upfitter wires to the harness.
Then the ground terminal would go to the negative terminal of the battery.
Included would be 6 x 2 pin male connectors pre wired with ~6" of wire for the user to splice to their desired accessory, assuming it doesn't come with a 2 pin deutch connector already on it.
Preorder page open. https://cblightingdesigns.myshopify.com/products/upfitter-wiring-harness
Will take orders till the 24th and them
Place material orders. Lead time for delivery is 4-6 weeks from the 24th.
We will shoot for earlier if we can.
This is a sample harness:
Instal pictures from @beo_tom
Credit for the harness idea goes to @beo_tom. he recently shared his upfitter harness that he created for his truck and there was interest in it from other members. He mentioned possibly collaborating with me on making them for folks so i reached out to him and we have been working on refining the harness design, creating the parts list, and working out pricing.
Upfitter Wiring Harness
This is a preorder in order to determine the correct order quantities for materials. Material orders will be placed on November 24th based on harness orders. Lead time would then be 4-6 weeks after that. Turn the short, poorly placed, hard to get to factory upfitter wires into easy to access...cblightingdesigns.myshopify.com
