Putco emblem.
Whichwaysup
North Carolina
2022 Atlas Metallic Blue Tremor
Hey y’all
I have a Petco emblem that I am planning on installing on the front of my truck. I’ve seen that I don’t need to remove the grill to get the old one off and the new one installed.
How hard is the wiring? Is it going to take a while or is it a quick job? Just wanna plan my timing appropriately.
I just installed mine a couple of weeks ago. Very first video I saw consisted of removing the entire grill. Then I read about a couple of folks just sticking their hands through the grill. Now, I’m not a big guy….so, I don’t have real big hands. I did not see how I would be able to do it without removing the grill…it’s just too tight.
So, I removed the grill. It was not hard at all. Make sure you do it on a warm day. If it’s a cold day, the plastic around the lights that you have to pull off “could” break. If it’s warm, it’ll take a lot to break it. Anyway, just take your time…it was worth removing the grill so that I could see everything. Took me a couple of hours total.
Just my .02 cents. LOL
I was able to get mine installed without removing the grill. Very easy to do. I’ve got the wiring run, but I can’t find the fuse location that I’m supposed to put the add-a-fuse into. It says fuse 18. Where the heck is that?
IIRC: The fuse 18 was changed and Putco never updated the instructions.
I hooked mine up to the #6 outfitter switch.
I also was able to install mine without removing the grill.
Details are buried somewhere in this thread:
I was able to get mine installed without removing the grill. Very easy to do. I’ve got the wiring run, but I can’t find the fuse location that I’m supposed to put the add-a-fuse into. It says fuse 18. Where the heck is that?View attachment 45799
Ahhh…I see you don’t have a 24+. I think your grill openings are bigger. Good for you.
Did you look in your owner’s manual for the fuse box? That’s where I found mine.
I finally found a youtube video with a guy who explained that they changed the fuses in ‘21 and now there is no #18. He used #22 and it worked. I did the same and we are golden . . .
Except that - just before I started the project, my drivers side @Cblaxx19 light went out! :(.
Claxx - any guidance on troubleshooting?
Talk about bad timing! I never got the full effect!
Oh yeah….your grill openings are much bigger than the 24+.
I know once of your lights went out, but it does look good!! I love the lighted Ford emblem.
Thanks @T-Rob ! I hope to get that light figured out today.
