What’s wrong with my truck
Nickac
California
2016 F-150
So I’ve been having weird issues with my truck and random faults.
Intermittent electrical/module issue across multiple systems:
  • BLIS fault comes on randomly, clears after restart
  • Reverse auto braking unavailable / see manual message
  • “Check brake system” warning occurred, cleared after restart
  • Audio issue where only tweeters worked — fixed temporarily by reseating the B&O amplifier connector
Issues are intermittent and reset with key cycle
Any ideas?
Adding to this. I have some aftermarket items.
Dash cam
Off road lights
Ham radio
I did stack my grounds from these items on factory ground points with OE wiring. Maybe I should run them to a separate location. 🤔 a new universal ground terminal strip I can run from the battery and put all factory wiring back with no aftermarket devices stacks on the bolt
What year is your truck? How old is your battery? Some of these may be low voltage issues.
Oh yeach 🤦‍♂️ 2021 battery is a 18 months old. Interstate AGM
Check my battery voltage this morning while sitting all night 12.17v 13.3 while running (cold start) after 5 minutes of running 14.5 volts
