2.5” level wheel/tire set up question
Trmorlife87
Utah
2026 F150 Tremor 5.0
F150 tremor 2026! I am a moron when it comes to this stuff so need your expertise
2.5” level RC coil over I want 35” tire 12” W on 18x9 - 0 offset wheels. Do I need a negative offset ir Will this set up rub you think? Any tire recommend that people notice don’t rub as much with the tread pattern?
Less Positive/More Negative is more rubbing. Consider an 11.5” tire instead and +20 or +25 offset. A 12.5” tire probably needs the 0 to keep the tires from rubbing the oem skid plate but they will rub the liner and the crash bars.
