TSB 2021–2023 F150 Diagnostic Trouble Codes — 26-2391
Technical Service Bulletins
F150 Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2391
Published: Sep 3, 2026
Applies to: F-150 (2021–2023 model years)
Summary (official text)​
This bulletin updates 26-2206. Reason for update: update the Service Procedure to revise Steps 19-21, adding Step 22, and adding Figure 15-16 to clarify connector C316 location. Some of the vehicles listed in the Model statement above may exhibit diagnostic trouble codes (DTCs) C1001:31, U3000:89, and/or U3000:49 stored in the image processing module A (IPMA) and at least one of the following conditions: • "Front Camera Fault Service Required" message • Pre-collision assist inoperative • Adaptive cruise control inoperative • Front windshield camera alignment routine fails to complete This may be due to the coaxial cable between the IPMA camera and the IPMA.
Sources​
  • TSB 26-2391 (PDF, NHTSA document 11037297) — Sep 3, 2026
