TSB 2021–2023 F150 Harsh Engagement — 26-2395
Technical Service Bulletins
F150 Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2395
Published: Aug 26, 2026
Applies to: F-150 (2021–2023 model years)
Also listed in the source (outside this forum's coverage): Explorer 2020–2023
Summary (official text)​
This article supersedes 26-2287. Reason for update: update the labor operation numbers to add MT to operations C, F, G, H, J, K, L and M, and correct the part number LIMZ-4A015-B to L1MZ-4A015-B. Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions: • Harsh engagement • Delayed engagement • Harsh shift • Delayed shift • Illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTC)s P0751, P0752, P0756, P0757, P0761, P0762, P0766, P0767, P0771, P0772, P2700, P2701, P2702, P2703, P2704, P2705, P2707, P2708, P0729, P0731, P0732, P0733, P0734, P0735, P0736, P076F, P07D9, P07F6 and/or P07F7 stored in the powertrain control module (PCM) or transmission control module (TCM). This may be due to axial movement of the CDF clutch cylinder sleeve causing hydraulic circuit leaks. NOTE: If internal transmission service is required to address a concern detected with the CDF clutch cylinder following this article, technicians should carefully inspect and replace other transmission components and flush transmission fluid cooler only as ne
Supersedes: TSB 26-2287
Sources​
  • TSB 26-2395 (PDF, NHTSA document 11036595) — Aug 26, 2026
