TSB 2021–2025 F150 Blank Center Display Screen or Black Center Display Screen — 26-2442
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 23, 2026
F150 Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2442
Published: Oct 14, 2026
Applies to: F-150 (2021–2025 model years)
Restrictions stated in the source:
  • Equipment: equipped with SYNC4
Also listed in the source (outside this forum's coverage): Bronco 2021–2025, Bronco Sport 2025, Edge 2021–2024, Escape 2023–2026, Expedition 2022–2024, F-250 SD 2023–2026, F-350 SD 2023–2026, F-450 SD 2023–2026, F-550 SD 2023–2026, Maverick 2025, Mustang 2024–2025, Mustang GTD 2025–2026 and 3 more
Summary (official text)​
This bulletin supersedes 26-2297. Reason for update: Add 2022-2025 Transit vehicles. Some of the vehicles listed in the model statement above equipped with SYNC4 may experience a blank center display screen or black center display screen after welcome animation. The rear-view camera will still function when shifting the vehicle to reverse under these conditions.
Supersedes: TSB 26-2297
Sources​
  • TSB 26-2442 (PDF, NHTSA document 11038617) — Oct 14, 2026
Details from NHTSA as of Oct 23, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
