F150 Tremor Forum
Forum Support 🛠️
- Oct 9, 2026
- 28
- 4
Technical Service Bulletin · TSB 26-2448
Published: Oct 27, 2026
Applies to: F-150 (2021–2026 model years)
Supersedes: TSB 25-2236
Details from NHTSA as of Nov 4, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Summary (official text)
This bulletin supersedes 25-2236. Reason for update: To consolidate prior articles and revise the Service Procedure to add an AAD blade limit strap. Some of the vehicles listed in the model statement above may exhibit at least one of the following conditions: •"Active Air Dam System Fault See Manual" warning message displayed in the instrument panel cluster (IPC) •AAD hanging/not retracting •Diagnostic trouble codes (DTCs) C0604 and/or C0630 stored in the powertrain control module (PCM) •Stuck/inoperative AAD blade •Deformed AAD blade and/or static lower valance that inhibits normal up/down function of the AAD blade This may be due to the software in the PCM, damaged fasteners and/or a deformed AAD blade.
Sources
- TSB 26-2448 (PDF, NHTSA document 11038916) — Oct 27, 2026
