TSB 2021–2026 F150 Illuminated Malfunction Indicator Lamp — 26-2432
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 23, 2026
F150 Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2432
Published: Oct 16, 2026
Applies to: F-150 (2021–2026 model years)
Summary (official text)​
This bulletin supersedes 26-2238. Reason for update: To update the Service Procedure to include diagnostics for the fuel vapor vent valve and the fuel tank isolation valve. Some of the vehicles listed in the Model statement above may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P2450 stored in the powertrain control module (PCM). This may be due to a concern with the fuel vapor vent valve and/or the fuel tank isolation valve.
Supersedes: TSB 26-2238
Sources​
  • TSB 26-2432 (PDF, NHTSA document 11038615) — Oct 16, 2026
Details from NHTSA as of Oct 23, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
