SSM 2021–2026 F150 Power Train — 55331
Special Service Messages
Imported from NHTSA data · last checked Nov 18, 2026
F150 Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 55331
Published: Nov 11, 2026
Applies to: F-150 (2021–2026 model years)
Restrictions stated in the source:
  • Transmission: 10R80
  • Equipment: equipped with the 10R80/10R80MHT transmission
Summary (official text)​
For 2021•2026 F-150 vehicles equipped with the 10R80/10R80MHT transmission, a new "All Clutch Variance Detection Test" has been introduced in the Ford Diagnosis and Repair System (FDRS). This test is designed to assist in diagnosing transmission shift quality concerns when no diagnostic trouble codes (DTC) are present. It evaluates transmission adaptive behavior over time to help identify clutches that may be experiencing performance issues. The "All Clutch Variance Detection Test" must be performed before clearing keep alive memory (KAM), DTCs, and transmission adaptive tables. If FDRS says the test will not complete, refer to the transmission clutch circuit leak test. If a variance is identified, refer to the Workshop Manual (WSM), Section 307-01 > Diagnosis and Testing > affected A-F Clutch. If a variance is not identified, proceed to WSM, Section 307-01 > Diagnosis and Testing > Diagnosis By Symptom. Variations in adaptive behavior do not necessarily indicate a transmission concern, as they may be impacted by unique driving patterns or habits. WSM updates incorporating this diagnostic procedure are
Sources​
  • SSM 55331 (PDF, NHTSA document 11039962) — Nov 11, 2026
Details from NHTSA as of Nov 18, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
