SSM 2021–2027 F150 Various Symptoms Including But Not Limited to the Auto Start/Stop… — 55315
Special Service Messages
Imported from NHTSA data · last checked Nov 18, 2026
F150 Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 55315
Published: Nov 9, 2026
Applies to: F-150 (2021–2027 model years)
Also listed in the source (outside this forum's coverage): Bronco 2021–2026, Bronco Sport 2022–2026, Edge 2021–2024, Escape 2022–2026, Expedition 2020–2027, Explorer 2020–2027, F-250 SD 2023–2026, F-350 SD 2023–2026, F-450 SD 2023–2026, F-550 SD 2023–2026, Maverick 2022–2026, Mustang 2024–2026 and 3 more
Summary (official text)​
Some 2020-2027 Ford/Lincoln vehicles may exhibit various symptoms including but not limited to the auto start/stop system not operating as intended with a battery light illuminated and/or charging system fault message in the instrument panel cluster (IPC). The charging system will be operating properly without charging related diagnostic trouble codes (DTC) stored. This may be due to someone using an aftermarket programmer to change the body control module (BCM) configuration to disable the auto start/stop system or perform other unsupported programming modifications.<br /><br /> To correct this condition, download and run the Ford Diagnosis and Repair System (FDRS) application titled "BCM-Charging System Configuration Correction". Running this application will determine if the BCM configuration was modified by the customer and if so, provide the option to return the configuration back to factory settings.<br /><br /> If the BCM Charging System Configuration Correction is not available in the FDRS toolbox and the vehicle is exhibiting concerns related to unsupported aftermarket BCM programming, submit
Sources​
  • SSM 55315 (PDF, NHTSA document 11039951) — Nov 9, 2026
Details from NHTSA as of Nov 18, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
