2021–23 F-150 Tremor 30" Behind-the-Grille Light Bar
mandronline
F150Tremor Sponsor
burbank california
2024 tremor
2021–23 F-150 Tremor Single 30" Light Bar
For anyone with a 2021–23 F-150 Tremor looking to add some extra lighting without putting a big bar out in front of the grille, we have a single 30" SLIM setup that mounts behind the grille.
It’s a bolt-on install using the factory openings and hardware, so there’s no cutting or drilling. The bar uses a spot + flood beam pattern, and you can get it in white, amber, or white with an amber DRL backglow.
The grille does need to come off for the install, and the factory emblem does cover a small section of the LEDs.
More info here: https://mandronline.com/products/2021-23-ford-f150-tremor-single-30in-light-bar
For anyone still looking to add some extra lighting to their 2021–23 F-150 Tremor, this single 30" setup keeps everything tucked behind the grille without changing up the front end too much.
The bar comes with a spot + flood beam pattern and has white, amber, or white with amber DRL options. We also have a light output video if you want to see how it looks in action.
Light output:
More info: https://mandronline.com/products/2021-23-ford-f150-tremor-single-30in-light-bar
