SSM 2022–2026 F150 Reduced Distance to Empty — 55111
Special Service Messages
F150 Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 55111
Published: Aug 21, 2026
Applies to: F-150 (2022–2026 model years)
Summary (official text)​
Some 2022-2026 F-150 Lightning vehicles may exhibit a reduced distance to empty (DTE) projection, a high voltage battery pack state of charge (SOC) that drops from 100% to less than 90% within 60 seconds of being driven, and an inability to reach a target SOC using the scheduled charging feature without any diagnostic trouble codes (DTCs) in the battery energy control module (BECM). This may be due to an issue in one or more cells within the high voltage battery pack. To correct the condition, run the "BECM Battery Health" application using the latest software version of the Ford Diagnosis and Repair System (FDRS). If any cells are identified as exceeding state of charge and/or capacity thresholds, refer to the Workshop Manual (WSM), Section 414-03A High Voltage Battery, Mounting and Cables > Diagnosis and Testing > High Voltage Battery, Mounting and Cables • Electric. Perform Pinpoint Test •High Voltage Battery Pack Cell Balancing Faults•, Step 4 (PPT Step AO4 for 2022-2024 vehicles/PPT Step AQ4 for 2024-2026 vehicles) and proceed with Pinpoint Test directions following the results of Step 4.
Sources​
  • SSM 55111 (PDF, NHTSA document 11036522) — Aug 21, 2026
