TSB 2023–2025 F150 Diagnostic Trouble Code — 26-2436
Technical Service Bulletins
Imported from NHTSA data · last checked Nov 5, 2026
F150 Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2436
Published: Oct 30, 2026
Applies to: F-150 (2023–2025 model years)
Summary (official text)​
Some of the vehicles listed in the Model statement above may have diagnostic trouble code (DTC) P05B0 stored in the powertrain control module (PCM) during a self-test. An illuminated malfunction indicator lamp (MIL) will be present on 2024-2025 vehicles with DTC P05B0 stored in the PCM. This may be due to a damaged lower active grill shutter housing end stops and/or vane lobe (allowing for over travel) or a lower active grill shutter actuator.
Sources​
  • TSB 26-2436 (PDF, NHTSA document 11038911) — Oct 30, 2026
Details from NHTSA as of Nov 4, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
