TSB 2023–2026 F150 Intermittent Extended Crank — 26-2360
Technical Service Bulletins
F150 Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2360
Published: Aug 5, 2026
Applies to: F-150 (2023–2026 model years)
Summary (official text)​
Some of the vehicles listed in the Model Statement above may exhibit an intermittent extended crank with no relevant diagnostic trouble codes (DTCs) present. This may be due to various software parameters in the powertrain control module (PCM).
Sources​
  • TSB 26-2360 (PDF, NHTSA document 11036075) — Aug 5, 2026
