F150 Tremor Forum
Forum Support 🛠️
- Oct 9, 2026
- 18
- 0
Special Service Message · SSM 55208
Published: Sep 25, 2026
Applies to: F-150 (2024–2026 model years)
Also listed in the source (outside this forum's coverage): Expedition 2025–2026, Explorer 2025, F-250 SD 2026, F-350 SD 2026, F-450 SD 2026, F-550 SD 2026
Summary (official text)
Some 2024-2026 F-150, 2025 Explorer/Aviator, 2025-2026 Expedition/Navigator, or 2026 F-Super Duty vehicles may exhibit diagnostic trouble code (DTC) U211B:43:48 stored in the body control module (BCM) when performing a Self-Test. This DTC sets due to an internal BCM timing issue during the self-test process. This specific code has no customer impact and does not cause any drivability concerns or warning messages. Clearing DTC U211B:43:48, reprogramming the BCM, or replacing the BCM is unlikely to prevent this DTC from setting. This DTC does not trigger a condition covered under warranty. Note: This guidance only applies to U211B with the specific failure byte 43 in status 48. Any other trusted real-time operation network (TRON) DTCs or different failure bytes associated with U211B are still applicable and technicians must follow Workshop Manual (WSM) normal diagnostics for those DTCs.
Sources
- SSM 55208 (PDF, NHTSA document 11037569) — Sep 25, 2026
