SSM 2024–2026 F150 Hands-free BlueCruise Feature Intermittently/Consistently Unavailable — 55071
Special Service Messages
F150 Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 55071
Published: Aug 5, 2026
Applies to: F-150 (2024–2026 model years)
Also listed in the source (outside this forum's coverage): Expedition 2025–2026, Explorer 2026, Mustang Mach E 2026
Summary (official text)​
Some 2025-2026 Aviator/Explorer/Expedition/F-150/Mustang Mach-E/Navigator vehicles may exhibit the hands-free BlueCruise feature intermittently/consistently unavailable when BlueCruise is active and when traveling in a "Blue Zone". Speed sign recognition may also be inaccurate. If there are no active relevant diagnostic trouble codes (DTC) present and the issue persists after multiple key cycles and if the BlueCruise System Health Check passes, download and run the "TCU - Reset Telematics Control Unit (TCU) Module" application using the latest software level of the Ford Diagnosis and Repair System (FDRS). If the condition is resolved, inform customers that this may be a temporary fix and engineering is currently working on a solution expected in Q4 2026. Monitor Professional Technician System (PTS) for additional information and schedule service appointments for customers once the repair becomes available. For claiming, use causal 14G229 and labor operations 12651D and 12651D4. If the condition persists after a test drive, refer to Workshop Manual (WSM), Section 419-03B for normal diagnosti
Sources​
  • SSM 55071 (PDF, NHTSA document 11036107) — Aug 5, 2026
