F150 Tremor Forum
Forum Support 🛠️
- Oct 9, 2026
- 34
- 4
Technical Service Bulletin · TSB 26-2476
Published: Nov 18, 2026
Applies to: F-150 (2024–2026 model years)
Details from NHTSA as of Nov 25, 2026. If NHTSA or Ford revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Summary (official text)
Some of the vehicles listed in the Model statement above may exhibit all of the following conditions: *Illuminated malfunction indicator lamp (MIL) *Illuminated powertrain malfunction (wrench) indicator *Reduced engine power with diagnostic trouble code (DTC) P061B and/or P168E stored in the powertrain control module (PCM) This may be due to the software in the PCM.
Sources
- TSB 26-2476 (PDF, NHTSA document 11040063) — Nov 18, 2026
