SSM 2024 F150 Inoperative Welcome/Approach Detection Lights — 55194
Special Service Messages
F150 Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 55194
Published: Sep 23, 2026
Applies to: F-150 (2024 model year)
Also listed in the source (outside this forum's coverage): Mustang Mach E 2021–2024
Summary (official text)​
Some 2021-2024 Mustang Mach-E, 2025-2026 Navigator and 2024 F-150 vehicles may exhibit inoperative welcome/approach detection lights. This may be due to the body control module (BCM) software. To correct the condition, download and run the "BCM - Programmable Module Installation (PMI)" application using the latest software level of the Ford Diagnosis and Repair System (FDRS) scan tool. If the condition persists after PMI, refer to Workshop Manual (WSM), Section 417-01 for normal diagnostics and repair as necessary outside of this article. For claiming, use causal part 15604 and labor operations 12651D and BCM.
Sources​
  • SSM 55194 (PDF, NHTSA document 11037561) — Sep 23, 2026
