mandronline
- May 15, 2025
- 38
- 19
- burbank california
- 2024 tremor
*** Don’t Forget, Forum Members Receive a 10% Discount!!! Use Coupon Code F150Tremor ***
Hey guys,
Upgrading your truck should not be difficult or overly expensive. We’ve got a DIY solution that’ll save you time and money. Check out one of our most popular light bar kits for the Light Duty trucks. Meet the 2024+ Ford F150 Tremor 40in Light Bar PRO
This kit is super easy to install:
1) No drilling required. Complete bolt-on.
2) No grill removal required; super easy install.
3) Lifetime warranty
4) Can tap directly into your AUX switches if equipped. If not we have the perfect solution (M&R Wireless Harness).
Fits Ford F150 Tremor with Modular Bumper ONLY years 2024 2025 2026
Main White LED Light with Amber DRL (daytime running lights)
Main Yellow LED Light with Amber DRL (daytime running lights)
Our light kits are for off-road use only.
For More information on the M&R Ford F150 Tremor 40” Light Bar PRO, Click HERE
Hey guys,
- Curved LED light bar PRO
- Perfectly follows the bumper and grille factory curvature
- Stays slim to the bumper for a sleek, built-in look
- Don't need to remove grille or bumper
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
- White LED — Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the oncoming traffic and also violate road safety.
- Amber DRL — amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads; it doesn't blind oncoming traffic.
- Yellow LED — used in poor driving conditions such as dust, fog, snow and rain. It reflects through air particles much less than the white light, making it ideal for poor driving conditions. For off road use only.
- Combo Pattern: combined spot and driving optics offer a balance between distance and width
- Uses a TIR (Total Internal Reflection) lens, which is different from our regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
