2024+ Ford F150 Tremor 40in Light Bar - PRO by M&R Automotive
mandronline
burbank california
2024 tremor
*** Don’t Forget, Forum Members Receive a 10% Discount!!! Use Coupon Code F150Tremor ***
Hey guys,
Upgrading your truck should not be difficult or overly expensive. We’ve got a DIY solution that’ll save you time and money. Check out one of our most popular lightbar kits for the Light Duty trucks. Meet the M&R 2024 Ford F150 Tremor 40” Light Bar - Pro.
This kit is super easy to install:
1) No drilling. Complete bolt-on.
2) You do need to remove the grille but we provide step by step video instructions for an easy DIY install
3) Lifetime warranty
4) Can tap directly into your AUX switches if equipped. If not we have a perfect solution (M&R Wireless Harness)
Fits: 2024–2026 Ford F150 Tremor
  • Curved LED light bar PRO
  • Perfectly follows the bumper and grille factory curvature
  • Stays slim to the bumper for a sleek, built-in look
  • Don't need to remove grille or bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
Choose light output color:​
Each PRO bar is dual-color — a main beam plus a soft amber DRL (daytime running light) backglow.
Option 1 — White + Amber DRL
  • White LED — Super bright, crisp white beam with plenty of light for any adventure. Off-road use only — it blinds oncoming traffic and isn't street-legal.
  • Amber DRL — Purely cosmetic amber glow. Street-safe — gives off little light and won't blind oncoming traffic, so you can run it on the road.
Option 2 — Yellow + Amber DRL
  • Yellow LED — Cuts through dust, fog, snow, and rain better than white light. Ideal for poor driving conditions. Off-road use only.
  • Amber DRL — Same cosmetic amber glow. Street-safe — won't blind oncoming traffic.
  • Combo Pattern: combined spot and driving optics offer a balance between distance and width
  • Uses a TIR (Total Internal Reflection) lens, which is different from our regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
👍Our light kits are for off-road use only.
For More information on the M&R 2024 Ford F150 Tremor 40” Light Bar - Pro, Click HERE
This looks pretty solid. I've been eyeballing your kit for a long while for the Bronco, but just recently arrived here and picked up a 2026 Tremor and am blow away there aren't more options that make use of that slit in the bumper for lighting.
Hope you’re having fun with the Tremor!
Check out the easy install process — and also check out just how bright the Ford 40in Light Bar PRO is...
We’re here to answer any questions.
