SpaceWhiteF150
Diode is lifetime!!Ahh okay.
I’m definitely learning towards the Morimoto 4 Banger instead of the DD 2.0’s.
Seems like they have better performance and definitely a better warranty.
Thanks just ordered it. Exactly what I neededif there is a seperate wire for the backlighting, I would run that to your marker lights and the main output to your upfitter. There are also wire harnesses you can plug directly into your headlight like the one from F150LEDs that give you the ability to tap into your power without splicing and cutting into your marker light wires.
I thought they were eight years.Diode is lifetime!!
Just went to lifetime within the last yearI thought they were eight years.
Okay, update. Just installed the kit. If you have factory LED headlights and fog lights the backlight on the DD SS3 will just work. It’s already pre wired into parking lights. The DD harness that is provided with the kit is all you need. It was a huge bonus and less wiring. For sureThanks just ordered it. Exactly what I needed
