35s No Rub - Full Articulation?
Tremgineer
ID
This is an excellent video demonstrating true 'no rub' under full flex and full steer.
However, the 315/70-17 BFG K03 in the video measures 34.4" x 12.7" (according to BFG specs)
I believe there is an error in the video for the wheel offset. I believe the offset of those wheels is +34 (same as Tremor OEM wheels).
Regardless, has anyone done a similar test using the C-Load Falken AT/4W 35x11.50-18 on OEM Tremor wheels? (which acutally measures 34.9" x 11.9" according to Falken specs)
Alot of you guys are 'no rubbing' in your driveway, but things change quickly when the suspension is compressed.
I have those Falken AT4W tires on OEM wheels. The measured width on OEM 7.5” wheels is more like 11.6”. Once the skid plate, crash bars, and liner cleared they were good with 6112s and a 1/2” strut spacer. The tires go the same places no matter what ride height you set with the coilovers and the 1/2” spacer makes a little room at the top for fully stuffed. I haven’t done the test they discussed but have been fully stuffed with no detectable rubbing. I can’t say I have had a wheel fully compressed and turned to lock, that would be a good way to break something
Thanks @deepblack for the testimonial. I was a little confused by your post - could you confirm if you had to do anything to the crash bars, liner, or skid plate to make them fit?
I am insistent on 18” AT/4Ws in C load: my only options are 35x11.50 or 285/70. The 285/70 is specified to be 34.0” x 11.5”, so it’s quite a bit smaller then your 35s.
