35X12.5X20
Not the greatest pics, but can confirm that 35x12.5x20 on 20x9 20mm offset fit with no trimming or rubbing with a 2.5" level.
Hey I love your set up, I currently have fuel Rebel 20X9 wheels with a +20 offset with 295/60R20 Ridge grapplers but want more tire so I'm about to order 35X12.5 nitto ridgrapplers, This should fit right? I was going to go 295/65R20 but the dimensions are even bigger than 35X12.5.. There's no rubbing on yours? Its on my 22 Tremor with pro comp 2.5.. Yours looks great but where I live I need to have kick back flaps by law so I'm worried the 35's wont fit when I turn full lock!
Did these end up fitting? I'm considering pulling the trigger on 20x9 fuels +1 offset with 35x12.5 falken wildpeak at3's.
Hey sorry for the late response, yes they did! I went with 35X12.R20 on a 20X9 wheel with +20 offset. I have a pro comp 2.5" level and there is no rubbing at all even with kickback mudflaps on! I'm not sure if a +1 wheel would rub or not... did you try yours yet?
Adding a 2.5" Pro Comp level and 20x9 Fuel Wheels with 20 mm offset
Dealer has concerns with running a 35x12.5x20
I see others have run this tire on stock wheels.
Does anyone have any thoughts on if these tires will fit or not?
His response was the difference in wheel specs over stock wheels will cause an issue
I am running that size on my 23'. Nitto Ridge Grapplers with no rub at all. Stock suspension with a 2" level kit. RR
