Hey,
I assume the first part was said with me in mind, so I’d like to address it first (hahaha). I agree that a linear piston and digressive piston can be shimmed to achieve a similar overall digressive feel. For example, Falcon uses what they calla linear-digressive valving by using a linear piston with a large washer on the back of their valve stack to create a higher crack pressure and thus an overall digressive shock curve (if I remember my visit to the Falcon factory correctly hahaha).
That said, a digressive shock and linear shock can and likely would have similar high-speed compression, the difference is low speed. For example, I specifically chose Bilstein 5100s for its digressive valving because I tow a lot and wanted more low-speed compression dampening to compensate for the trailer.
Re: ADS & Radflo — ADS, so far as I can tell, is just a basic 2.5” with an external adjustable compression knob (no independent high and low speed circuits, and no internal hydraulic bump compression and rebound ‘bump-stops’). Moreover, ADS is a progressive valving.
Radflow appears to have the same features (or lack thereof) but they don’t specify what kind of piston they have and “Velocity-Sensitive Deflective Disc, Self-Adjusting” is literally every shimstack ever (haha). The higher the force, the more oil flows, the more the valve shims flex and then snap back to their original position. If anything, this makes me trust the company even less.
Lastly there’s the intangible. Bilstein is arguably OEM quality from a serviceability / longevity standpoint, and outperforms everything else on the market from a performance standpoint as well. I welcome competition / options, but yeah. Right now they have the best tech available to the consumer.
@Machine — my gut-check says match the rear to the front because when companies are doing their shock tuning, they’re doing it with the own products and I’d be worried about poor or unsafe handling or even comfort from a frequency-tuning perspective, though I know springs play a big role in that stuff and I’m not a suspension expert, so that’s starting to get outside of my wheelhouse.
