Best leving kit for 2022 Tremor to fit 35 x 12.5
Tremor7B
Sandpoint, ID
No
2022 F-150 Tremor
1978 Jeep CJ5
Looking to put 35s on stock rims. Ideally I stay away from spacers. What leveling kit should I buy?
Depends on how much you want to spend. The Eibach 2/2R kit is pretty good. They say the Eibach Stage 3 is also really good but it’s back ordered literally every where with really an unknown timeframe. There are several other options you’ll find in the suspension section of this forum as well. If you aren’t looking to spend much, I’ve got a listing in the classifieds of the original setup I used on my 21 to run a 34x12. Not positive if it would work for a 35x12.50.
Ok thank you. Don't really want to spend a lot and thought a 2 - 2.5" leveling kit will do the trick. Anyone installed one successfully for 35 x 12.5 tires? If so, what's the model/brand?
For a 35” tire, it will be 1” higher above the axle than the OEM tires. So you will need ~1” spacer or a shock that has a 1” longer compressed length than stock. I have a 1/2” spacer (on top of the shock) and it doesn’t rub anything even when stuffed. But everyone’s truck is a little different so there’s no guarantee.
Just fyi I had the same rims/ tires on more than 4 trucks already and on 150s the
315/70/17 fits nicely under the fenders. Tried them on 2 tremors now and they stick out 1” front and back. The front rack and rear axle are not the same(or the body is skinnier but doubtful)
I went with 11 “ wide, pretty much under the truck
