Can you change digital Tach and Speedo?
I find it funny and frankly curious on its possibility because I’ve been in a few other models that have had this option. Take the Escape for example, it’s got a clear cut setting to go from a very similar gauge appearance of our trucks to a more analog looking gauge with sweeping needles
Mine is always there, even after a restart. I have a 2022
Interesting. Both of my 2013s behaved the same as my ‘24. Strange they have gone back and forth since 2013.
The Mustangs I believe have several options too
My '24 does not show the gears unless I hit the manual button. I will say when you give it about 60%-70% bean throttle the snappy shifts I couldn't replicate with my stubby thumb 🤣🤣
The gears should always show unless you disable said gear display by hitting the button on the shift handle.
One push of the button and it’s either always on or off.
If you have it on and if suddenly the gears aren’t displayed on the dash, that means that you accidentally / unconsciously hit the button without knowing it.
Right there
Yeah the 24-25 don’t show up unless you click the shifter buttons. We also don’t get the numbered rpm inside the circle 😔
This is exactly what I want for the F-150!
It’s one of my bigger annoyances with Ford that the gears aren’t visible at all times. But I grit my teeth and press the + button every time I drive the truck. 😬
My gears are always visible, too. (2023 5.0)
