Corsa Sport V8 - anyone have one?
Cool - I am curious to see if it is touring or the Type S
OK,
More info. I talked to Borla again and they reiterated that the Ford SPORT exhaust for the Tremor is in fact the Touring designed system. I purchased this system, P/N: M-5200-FSBRB and I found it had too much drone at high RPM under load. (It is a little quieter than the AWE I removed but has drone.)
It should also be noted (I was confused by this at first) that Ford also makes a Touring labelled system BUT...BUT...it is only fitted to a NON-TREMOR F150 and Borla tells me that system would sound the exact same as the Ford Sport system on the Tremor. The non-Tremor system is P/N: M-5200-FTRB and Ford does not list on their website that it doesn't fit the Tremor.
This has been a pain in the wallet to say the least...I'm on to Supercharger install....
Corsa Extreme on mine. Went with it over the sport just to make sure it sounded great when I'm on it. Couldn't be more happy with it. The installation was a breeze.
Not to mention sounding very loud /obnoxious and annoying to fellow drivers. 🤣
I have the corsa sport on my 5.0 also and love it. As noted above it's fairly mellow and deep tone until WOT and then it gets mean, which is what I wanted from past experiences with corsa exhausts on a v8. Maybe more importantly, there is no drone, if you've ever experienced drone you know that's a pita. I recently added SPD downpipes with their newer alpha cats and ended up having to add a small corsa resonator to quiet back to sport levels but it's even better now with similar to sport behavior but even deeper overall tone. Reached out to corsa and they were very helpful.
Likely can't go wrong with any of the companies mentioned above, I just go back to what I know I like.
Downpipes to the 5.0?
The Corsa Extreme is loud but only on prestart (and that's just a strong rumble) and when you're ON it. I drove from FL to MT with mine and NO DRONE @ ALL. I like the Extreme because it's full-on loud whenever I want it to be and just a great sounding exhaust otherwise. No half measures...
