Ditch light recommendations
I got the SS-c1 kit. It bolts directly to the side of the big light and you use a 4 pin connector to wire.
Stage Series C1 Yellow Pro Standard LED Pod (pair)
33 in stock.
SKU: DD6463P
Primary Optic: Flood
Backlight Color: Amber
These are the ditch lights I have Im pretty impressed with them and they dont give off that cheap look like most of the offroad lights do
Those are a nice choice. I'm normally a fan of their products. I had them in the bumper pockets on my Raptor. I went with Diode Dynamics this time because I liked those being a little smaller in the A pillar location.
Is there a kit to add the smaller lights or does it just use the base and nothing more?
no kit. just mount the smaller ones on the side of the mount for the bigger lights. you will need a y splitter if you want to run them on the same switch, otherwise a separate harness to run them to a different switch.
I always run these as ditch lights, have a set just sitting. They are a good option and you can get spot, flood or driving patterns.
