DIY NO DRILLING 2024 Tremor Modular Bumper 40inch light bar
Install was easy. I put the white on Aux 1 and moved my rear lights to aux 2. The amber is on aux 5. I have side vents on aux 6. Thanks for the Labor Day 15% Discount!
That looks awesome, thank you for your support! You guys can still use coupon code COLBY10 at checkout to get 10% off of your purchase.
Made a step by step installation video for our Pro 40 inch light bar let me know what you guys think! I will tag on the light specs as well!
Fits 2024 2025 Ford F150 Tremor with Modular Bumper ONLY.
  • Curved LED light bar PRO
  • Light bar is made out of 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant. With a rating of IP68, the light bar is dust-tight and water-proof.
  • Perfectly follows the Ford Raptor bumper and grille factory curvature
  • Stays slim to the bumper for a sleek, built in look
  • Don't need to remove grille or bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
DUAL COLOR​
Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and canโ€™t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • Amber DRL -- amber DRL โ€œdaytime running lightsโ€ acts purely for aesthetics. Since it doesnโ€™t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
Will if fit 24 Tremor with the Modular Bumper ?
It does! Here is the link so you can take a look. Just be sure to use coupon code COLBY10 at checkout to get 10% off of your purchase. We also love seeing our customers trucks after the install so we would love to see it once it is all set up!
2024+ Ford F150 Tremor Light Bar Kits
Cool story, since these are for Raptors...
So the same light bar lights up both amber and white? By wiring to two different switches? Or are the white bar or the amber bar two entirely different options?
FYI, for those considering pillar mounted ditch lights, I purchased a set from M&R recently. They have amber drl's built in, looks great and combines very well with the existing 40" light bar. Right now I have the white 40" on aux 1 white spot pillars on aux 2, the drl for pillars on aux 5 and drl for 40" on aux 6.
