SpaceWhiteF150
Looks great!
ThanksVery nice.
+1Okay, how do we get our hands on that beautiful bracket?
Unfortunately it's a one off custom and not repeatable.Okay, how do we get our hands on that beautiful bracket?
Ah man, It’s okay I almost have mine done. Did you do combo DD pros? Or wide fog beam?Unfortunately it's a one off custom and not repeatable.
Good stuff. They're all sae fog but thinking of switching the center to a combo to shoot a little further.Ah man, It’s okay I almost have mine done. Did you do combo DD pros? Or wide fog beam?
I’m going to switch my fogs to amber sae with the dd fog pocket then run 3 white combo pros in the middle!Good stuff. They're all sae fog but thinking of switching the center to a combo to shoot a little further.
I still have a set of vivid lumen ditch lights to put on as well
You could run the swarf works plate relocation or the built rite plate location!Awesome, I need to make this happen. I wish I didn't need a front plate! I'll need to make it work with one light each side
is the thin cut out on the top half for zip ties for wire management?View attachment 26287
Bracket has been fully made into a cad file! This is what I’m thinking will get the job done!
Yes the thin top slot is for zip ties to keep the wiring tight to the back. I wasn’t planning on bends, planning to cut it with 3/16 aluminum. I’ve been playing with the properties in fusion to test strength but can’t get it to work. I have a prototype in 1/4 aluminum and it’s overkill. Also the spacing to make it flush with the bumper is spot on with no bends!is the thin cut out on the top half for zip ties for wire management?
so you not think that you need a bend to give it some rigidity?
