Leveling Kit
Crafty68
Missouri
2023 Tremor
Looking for feedback from anyone that has installed the Stage 3 2.5" leveling pucks on a Tremor. Thinking of going the puck route on a new 2026 Tremor. Any issues or concerns would be greatly appreciated.
Just FYI, I don't have Stage 3 Kit, but do have ReadyLift 2" on my '23 Tremor.
Put on when truck was new (less than 500 miles), running 315/70R 17 KO2's since about 800 miles.
Just shy of 45K on the Odometer now with absolutely no issues. Tires are wearing normally and still have at least 10k more miles in the tires.
I don't do a tremendous amount of Off-Road Adventures but I do tow a Travel Trailer with a Gross Weight of about 7,500 lbs.
With a Weight Distributing Hitch it tows well and is within 1/2" of completely level when towing.
Got exactly 2" of lift out of the ReadyLift 2" Spacers and have approximately 1" of rake (rear higher) when unloaded.
Looks like Stage 3 sells the Auto Spring pucks. I put the 2.5" taller Rough Country struts on my 23 Tremor because I was told no one made the pucks for a Tremor. That put my front roughly 1/2" lower than the rear. Buying a 26 Tremor & found pucks but wanted to make sure there was no interference or issues. Thanks for your input.
One other note I forgot to mention. The kit I used was a “Tremor Specific” kit. At the time, as far as I know, ReadyLift was the only one with a kit specifically for the Tremor.
