Leveling lift
Most are happy with their choice of kit and most have brand preferences.
I’m a Bilstein guy and I’ve been very happy with the 6112’s and 5100’s but I’m going to upgrade to the 8112’s and 8100’s.
Also, unless your Ford dealership of choice sells aftermarket coil over kits, no Ford dealership will install said kit for you. Yes, there are always exceptions but it’s very rare.
I didn’t need any type of sensor recalibration with my Bilstein setup so I can’t speak on other brands.
I’m sure others will chime in to answer your question.
Have you made the switch yet to the 8112s and 8100s? If so, how are you liking them? Since I still have the front Halo/Elka's I plan to reuse those, but will likely replace the rears and am in the process of debating which brand and model to use. I've been looking at the Bilstein 8100s or 5165 but am open to other brands/models.
No, I haven’t maid the switch yet but it’s definitely coming by the summer of this year.
I’m sure I’m going to like them just as much as the 6112’s and 5100’s.😎
With that being said, since you already have the Halo/Elka front setup and I take it that you’re happy with it, why not just use the “matching” rear Halo/Elka setup?
Although many do it, I’ve never been a fan of mixing different brands of shocks.
Mostly I just want to tweak peoples’ OCD BWA ha ha haaaaa😈🤣
Halo/Elka doesn’t recommend the same model I used to have and the new recommendation is predictably more expensive- maybe not more expensive than the Bilsteins… but I was thinking of upgrading anyway.
I don’t have an issue using whatever is the best option even if it means mixing brands- so much of what I have in other things Is mixed but it would nag at the ocd a bit hehehe
I recently made the switch to the 8112s and 8100s. I couldn't be happier with them so far but once I go do some off-roading I can report back
Where did you order from I haven’t found a tremor specific part numbers.
For the 8112 8100 setup
Where did you order from I haven’t found a tremor specific part numbers. For the 8112 8100 setup
There are no Tremor specific part numbers as it's the same parts across the board for the F150. The only difference is the max height which will be stated in the install instructions.
Considering RC M1, not sure on the UCA or rears shocks yet. I do light off road, more concerned with wet and winter driving. I do light towing but use my bed to haul some weight occasionally so I am looking to keep some rake, maybe an inch or so.
Tires will probably be BFG KO3 285/75 18, I like the Tremor wheels and at 34.8 x 11.3 should be good all around with wheel and no rubbing concerns. That’s what I am thinking now, but always subject to change until it’s done, lol.
Figure I would ask here. New to 26 401A high package and no auto leveling headlight sensors.
Any issue with blue cruise after a level and do you need to calibrate?
some guy on facebook says can’t level these or use bigger tires and keep blue cruise
Sorry for the slow reply. I'd be interested to hear your thoughts after some offroading!
