TXtrailTremor
- Oct 19, 2026
- 2
- 6
- Fort Worth, TX
- Military
- USCG Aviation (Retired)
- 2025 F150 Tremor (402a), Space White
Howdy!
I'm trying to figure out the best way to get 12vdc power to the bed. My 2025 F150 Tremor has a Pro Power outlet in the back. My goal is to get 12vdc to a PoE injector which in turn will power the Starlink Mini mounted to the cab guard (headache rack). The PoE injector will deliver the correct voltage and wattage to the Starlink and also provide an additional wired Ethernet port. I'll mount it in the small passenger side storage compartment in the bed.
A friend had his wired into the 7-pin trailer connector. I've tried to figure out which pins are engine/accessory on connections but no luck. Is there constant 12v power there or only "on" power? I'm trying to avoid having the Starlink powered on all the time. I have thought about using an upfitter switch.
Any suggestions from those more 'in the know" would be greatly appreciated.
