Khalil
I came across this new fog light kit specifically made for the 2024–2026 F-150 Tremor and thought it might be worth sharing here, especially for anyone who has been looking for a cleaner way to add more front-end lighting without cutting or drilling into the truck.
The kit is made for the Tremor with the modular bumper and replaces the factory fog light setup with four M&R Automotive PRO Series pods, two 20W pods and two 40W pods. The way they have the pods set up is pretty interesting; the 20W pods are angled 15 degrees outward for a wider fog-style beam, while the 40W pods point straight ahead with a driving beam for more distance. So instead of having all four lights doing the same thing, you get more spread up close while still having some distance down the road/trail.
The install also looks pretty straightforward. It’s a bolt-on setup, and the brackets reuse the factory bolts and clips. The kit includes the two metal brackets, two 3D-printed shrouds, wiring harness, and H11 factory adapter wiring.
Another thing I noticed is that you can choose white or yellow for the main light output. The 20W and 40W pods can actually be selected separately, so they don't necessarily have to match. Both options also have an amber DRL backlight.
The yellow option seems like a good choice for anyone who spends a lot of time driving through dust, fog, rain, or snow, while the white option gives you that more traditional bright off-road lighting look. The product page also mentions that the main beams are intended for off-road use only, so that's something to keep in mind.
They also have some videos showing the installation, the PRO pods themselves, and the actual light output:
Install video: https://www.youtube.com/watch?v=C-9yJw6Dnp0
PRO Fog Lights Pods: https://www.youtube.com/watch?v=WeZ_LeiVVHo
Product Page: https://mandronline.com/products/2024-ford-f150-tremor-fog-light-kit
One thing to note with the wiring: the included harness connects both sides and runs into the engine bay for the truck's AUX switch wiring if equipped. If your Tremor doesn't have AUX switches, you'll need a separate generic harness or can use their wireless harness option. I think the biggest appeal here is the fact that it keeps everything pretty clean and doesn't require drilling into the bumper.
Would you rather run white or yellow for the main pods?
And if you were adding more front lighting, would you prefer a setup like this that stays tucked into the factory bumper area, or would you rather run a light bar / separate pods?
