Orange accent console liner/mats
I received them today and the orange is REALLY orange and not really color matching
So I got these today. I have mixed feelings but also for $35 I'm not too upset. So they are not as grippy on the bottom as I would like. I could see them possibly moving around a little.
As Jordan said the color is a darker orange than our trim color orange. It's not vastly different but it is.
The cupholder inserts seem worthless to me because they were cut to fit over the existing ones. So unless you just love the color, those are pointless. Also if you have the wireless charger the insert is again worthless, it only fits if you take out the original insert out, but that insert has the bumps to hold your phone in place. Without it your phone won't sit right to wirelessly charge, and not taking a cue from the cupholder, this one will not fit over top of the original.
So overall I am happy, I'll use them for now, minus the cupholder ones and the slim one next to the shifter, that one is also designed to fit over the existing one, making that slim opening even smaller.
Onto the obscene amount of pictures.
Cupholder next to the stock one, you can see it is smaller.
Here it is in the hole without the factory one underneath it, it's too small.
Here it is perfectly inside the factory one.
This slim center piece is meant to sit on the bottom of the stock piece.
Seems pointless to me.
It does kind of work without the stock piece, but I don't see why you'd remove the stock piece. I put my phone in there and love that the stock one is so grippy on all sides.
The money shot, the color against our tremor orange piping.
Drivers side rear door lower
Drivers side rear door upper
Passenger side door lower
Passenger side upper
Center console side pieces, I was pleasantly surprised with these ones, which were honestly the original reason I even wanted these. They fit pretty well and offer grip where before there was none.
In summary, for $35 I say go for it and use the pieces you want, color isn't a perfect match but isn't horribly off either. .
Nice to see those pictures. Overall, I think they look nice. In the case of the front cupholder pieces being smaller, perhaps I'll be able to still use them once I install the lighted cupholder. Was there no piece for the tray on top of the dash?
Big Cam, thanks for the picks. How do you think the door ones will stay put? I think I will get the blue to match my truck and just use the door and center console pocket ones. Ford does make the best inserts I have found. Too bad they didn't fully replace them. thanks again.
If I find they don't stay in place, I'll use a little of this. If you decide to take them out later, any residue can be removed with bug & tar remover or paint thinner.
Yes there was. A piece for literally every possible cubby hole or storage spot. This one also goes over the original, otherwise it won't fill the space. There is what looks like a pen holder on the original that the new one doesn't come with.
I think they'll stay in the doors, they may move slightly, I mean like less than 1/4th an inch, but they'll stay put.
I think once they settle in they'll be fine. I had some in my 14 Tremor and never had any issues with them.
Looking at the factory cupholder piece again, I don't think those would work if you do the cupholder conversion. They would cover the lighted part up. The orange trim one's appear they will fit and allow for the light to show.
OE inserts dont cover the lights so as long as the orange ones dont add like ~5mm of height it should be fine
Got mine today. They came late, so didn't put them in yet. The orange is bright but I'm fine with that.
In stock again fyi if anyone else was waiting on orange
Anyone order these ? Do you think the orange accent will be close to stitching and such ?
CupHolderHero fits Ford F150 Accessories 2021-2022 Premium Interior Non-Slip Anti Dust Cup Holder Inserts, Center Console Liner Mats, Door Pocket Liners 38-pc Set (Bucket SuperCrew) (Orange Trim) https://www.amazon.ca/dp/B09JPKKYMM?tag=f150tremor-20
reviews ok.... anyone on here have them and can share input?
I got mine from another source, but they appear to be the same manufacturer. Some of the same photos are used on both sites. I'm pleased with mine. They've been installed more than a month and so far, no curling or any issues.
couldnt help myself ~ just ordered !
