Tell me how bad it is to use wheel spacers
I did a 2” readylift, I wanted spacers to get the tires to poke out a little. This 35” tires about the same width as the stock it’s not much wider.
Here is another shot for those contemplating wheel spacers, I’ve found some 0 offset method wheels so I’ll be getting rid of the spacers soon.
I personally would go for the +25 offset wheels. I have MR703s in +0 and I cannot fit 35x12.5s on here because of it. Once these 295s are through I’m selling these for the +25 one’s.
0 offset will create quite a lot of poke and potential rubbing issues, I put fender flares on to hide it because it was a little much.
I like the poke, and I prefer the 285/75 so 0 offset will work for me. For a 12.5 you’d need a 25+
Correct offset is key. I don’t see how folks don’t rub with some of these lower offsets when stuffed. I had to massage the back fender wells with +18 due to the contact it was making with a 35x12.5.
Easy, they don't rub because they only go to the mall parking lot so they never stuff a tire.
Hahahah sounds like you’re a pro off roader and rock climb with your truck often huh?
I have four 10mm (3/8") hub centric spacers for sale in the classifieds if anyone is interested. These are new/unused condition.
