Tow mirrors
Highly likely/guaranteed you'll have to recalibrate. You'll need to do the telescoping change at least but, I did the below for the amber marker lights as well. I think there's a couple other things you can fart around with like puddle lights but mine worked fine/how I wanted out the gate so I didnt touch it.
BCM Mirror Marker Lamps - 726-40-01-xxxx-xx01-xxxx
What is the ford part number for the tow mirrors you installed that work with the 2025 and have all the options? This part number one you guys are using? ML3Z-17696-DA
Im in the same boat with a 2025. On the Fairway Ford link that was shared on page 1 it has a check to see if it fits. It said it did for mine, 2025 402A, but they also do VIN checks.
Also seems like the part number DA is on backorder with no available date with a note that it is being redesigned.
Yes they are back ordered I tried to get a set from ford back in June 2025 and when I called few weeks ago still no ETA. I found a set of the DA tow mirrors a guy was selling. Got them on and working just can’t get the power fold to work not sure I have tried everything on FORScan no go. Have it booked in to ford dealer Friday hopefully they can figure it out.
Awesome and odd that power fold is not working. Most say only power telescoping has issues. Good luck at the dealer!
