latapx
- Oct 12, 2026
- 6
- 14
- FL
- 2025 F150 Tremor EB
- Current Ride #2
- 2023 Subaru BRZ
I tow often with my Tremor...about 4k of the 15k miles it has on it has been with the trailer and equipment on board.
This is my typical setup and loaded stance of the truck.
The bed does have tools, etc in it...and this is the "light load" as the fuel jugs are empty. When they are full its another 250+lbs near the front of the trailer and I'll typically place a car a touch further back to balance things out.
1450# trailer - 2700# car - 400# "stuff" on trailer gives roughly 4550#...not a lot.
Then maybe another 350# to 400# in the bed depending on the weekend.
While towing at 75 - 78 on cruise control I'll see water temps rise to 217F to 219F in South Florida...so flat, but hot and typically windy. I also run premium when I tow to help combat heat/knock, etc. Is this typical for these trucks? The trans is usually cooler so it seems to be doing fine. Truck is 100% stock.
On the suspension side...it does tend to bounce a bit...seems like its bouncing off of the bump stops all the time so I need to address that with Timbren or RAS and upgrade shocks at some point.
Just looking to check in and make sure temps are good, or if there are items that should be done for long term reliability when towing.
Thanks!!
Thanks!!
