Sully
Everyone is different but as someone with multiple hernaited discs,, sciatica, nerve damage and need a hip replaced I find em quite comfortable and it's cause of the multi way power adjustments. I can really dial it in
Also 5'7", no issue with seats. Are you what would be considered a healthy weight?I am 5'7" - and I am 3000 miles in and ready to trade the truck in. I cant drive an hour without my back and shoulders hurting. The bucketed feel for a shorter person makes me feel like I'm sitting in a V shape and with how high the seat sits naturally, it applies an uncomfortable pressure on the bottom of my thighs also. I bought Desert Does it Blocks and installed them in the rear to unbucket the seat a bit, but the more "C" shape of the seat back compressed my shoulders forward and is just not sustainable.
Trying to figure out a solution, even took the truck to a custom upholster and nobody seems confident they can fix that spot your pointing out. Unfortunate, because the truck drives like a charm.
I am a healthy weight. With being the same height as me, the seat does not push your shoulders forward? Makes feel like I’m being forced into a hunchback position.Also 5'7", no issue with seats. Are you what would be considered a healthy weight?
im the same feeling. im 5'10 160 and the hamstring/ back of knee area tire out occasionally. never an issues with butt up to head.I'm 6' and just about 190, and I find the seat to be comfortable on my back. I definitely don't get the feeling of being forced into a hunched position. However, sometimes I feel the end of the seat hits my hamstrings in a weird spot.
The feeling I get is like the edge of the seat is pressing on a nerve in my hamstring. I adjusted the tilt of the seat forward a little, and it helped. It's not horrible, and I mostly notice it on long drives.im the same feeling. im 5'10 160 and the hamstring/ back of knee area tire out occasionally. never an issues with butt up to head.
Not sure about the shoulders being forced forward but I did find that I have to sit more reclined in these (402a leather) seats then other vehicles. I prefer to sit more upright due to a really messed up back but found a more reclined position more comfortable in these, also have to drop tbe front of the seat base, again usually like it up so you sit in the seat but this one I'm almost sliding out forward. And don't get me started on tbe pedals, so overall I find tbe seats good but the pedals are horrible.I am a healthy weight. With being the same height as me, the seat does not push your shoulders forward? Makes feel like I’m being forced into a hunchback position.
Can't say that I have noticed that in 20k miles, but I'll pay attention next time I'm in the truck. I do have wide shoulders, do you feel like there is not enough support in the middle and are sinking back too far or something?I am a healthy weight. With being the same height as me, the seat does not push your shoulders forward? Makes feel like I’m being forced into a hunchback position.
Did you ever find a solution? I just purchased and have the same issue. On my left side I feel a hot spot and like it’s a little tiled. Almost same size as you.WELL, I'm in the camp with you on the seat issues only mine is a different one. The 'bucket' style of seat is uncomfortable for my left leg. AND, I feel like I'm rolling off the seat to the left when I'm turning the truck to the right. It's the strangest thing, it's like the seat is tilted to the left to some degree or the seat support on the left side is sprung or something. I LOVE this truck but my 2.5 hour travel times get the best of my left leg and given me sciatica issues. I'm 6'3 and 230. I have a 2016 F150 Platinum and those seats are great. I've even gone to the dealer and sat in other tremors to see if this is unique to mine. It's hard to tell in a test drive or just a sit in...it may cause me to trade it in tbh.
I have not. I’m taking it in on the 8th to get them to look it over. The seat part is moving if you put your hands on it and you can move it back and forth. Also, I have pics and you can see the difference btw the driver side and passenger side seats. If you look closely you can tell the right side of the seat is higher than the left side. The passenger side looks to be level. I’ve had this problem since I got the truck. At first I thought it was the suspension of the truck causing problems or the truck being higher than other models.Did you ever find a solution? I just purchased and have the same issue. On my left side I feel a hot spot and like it’s a little tiled. Almost same size as you.
Thanks. Please reply back if you make some progress. I might have the dealership look at it but I suspect they will just shrug it off or not find anything.I have not. I’m taking it in on the 8th to get them to look it over. The seat part is moving if you put your hands on it and you can move it back and forth. Also, I have pics and you can see the difference btw the driver side and passenger side seats. If you look closely you can tell the right side of the seat is higher than the left side. The passenger side looks to be level. I’ve had this problem since I got the truck. At first I thought it was the suspension of the truck causing problems or the truck being higher than other models.
Any update?I have not. I’m taking it in on the 8th to get them to look it over. The seat part is moving if you put your hands on it and you can move it back and forth. Also, I have pics and you can see the difference btw the driver side and passenger side seats. If you look closely you can tell the right side of the seat is higher than the left side. The passenger side looks to be level. I’ve had this problem since I got the truck. At first I thought it was the suspension of the truck causing problems or the truck being higher than other models.
