Two Hidden Light Bars. One Incredible Upgrade.
mandronline
burbank california
2024 tremor
šŸ‘‰Forum Member Get 10% Off, So Don’t Forget To Use Discount Code ā€œF150Tremorā€ at Checkout!! šŸ‘ˆ
If you've been thinking about upgrading your 2024+ Ford F-150, check out M&R Automotive's Dual 30" Light Bar Kit. It's designed to give you serious nighttime visibility while keeping a clean, OEM-style appearance.
The kit mounts two 30-inch SLIM LED light bars neatly behind the factory grille, so you get plenty of usable light without bulky brackets hanging off the front of your truck. It's a complete bolt-on kit with no cutting or drilling required, won't interfere with the active grille shutters, and fits 2024–2026 F-150 XL, STX, XLT, Lariat, King Ranch, Platinum, and Tremor models. You can also choose from White, Amber, or White with Amber DRL Backglow to match your driving style and build.
Features:
  • Dual 30" SLIM LED light bars
  • Hidden behind-the-grille, factory-style appearance
  • Complete bolt-on installation
  • No cutting or drilling required
  • Vehicle-specific mounting brackets and hardware included
  • Compatible with factory active grille shutters
  • Available in White, Amber, or White + Amber DRL Backglow
  • Lifetime warranty
  • Off-road use only
We also put together a complete install video that walks you through the process from start to finish.
If you've been considering adding hidden lighting to your F-150, this video is a great place to start. Let us know if you have any questions about fitment, installation, or which light output is right for your truck!
We've had a few people ask how our 2024+ Ford F-150 Dual 30" Light Bars perform at night, so we wanted to share this light output video. It gives you a good look at the beam pattern, light spread, and the kind of visibility you can expect out on dark roads and trails.
As always, if you have any questions about fitment, installation, or choosing the right lighting setup for your F-150, feel free to reach out. We're happy to help!
