Underseat (rear) Storage
I now have a 2022 silver tremor and the Tuffy lock box I had in my 2019 F150 fits in my new truck without any problems.
would cool if there was one that was a platform that took up all the space so my dog could still sleep on it..
I have 2 car seats at the back so all the box solutions were out. Saw some pullout boxes but seems a bit expensive for a storage solution.
I also have husky mats and anything I shove under the seat flies all over the place. Best solution I found so far is to put $6 drawer liner on top of the husky mat and shove everything on top of it. Whatever I shove under that is staying in place without moving
Did you remove those screws? Looks like they poke out a bit without the storage, or maybe it's just the pic. I'm also leaning towards removing mine. I didnt think through the storage being unusable with car seats installed.
I did remove the screws. The 2 on the passenger side came out easy from underneath the truck, but the 2 on the driver’s side are blocked by the gas tank. I used pliers to unscrew them from the top then had to get creative to get them out. I ended up hooking a cargo strap to the stud from underneath and tugging on it with one hand while I pushed the stud down with an awl from the top with my other hand. It worked but there was sweat and cussing involved! Just went down to ACE hardware and got some plastic plugs to stick in the holes and I’ll cut up an old floor mat to fil in where the carpet is missing. It’s REALLY nice to have a full flat rear again! I didn’t realize how much just that 1.5” or so was in the way!
Damn - right now my studs are just sticking up into the floor mat! Sounds like this is one of my next projects.
cool. thanks I think I might end up going this route.
Please keep in mind this one has been used for 4 yrs. I just took it out of my fx-4 and installed it in my tremor.
I have the same situation. I bought it for my 19 FX4 and moved it over to my 22 Tremor. I love it and it has plenty of storage. Would recommend to anyone looking for one.
I just got the husky and it dose not fit, the du-ha looks like it fits like a glove.
It does and in most states will count as a locked case for firearms.
I have had this one for 6 years now and still as good as new.
I just pulled the trigger on the Du-ha. I had the non-lid version in my '18 F150 and it was awesome. I was going to get the undercover swing boxes, but I've been my entire bed a lot lately and it would cover up the bed lights.
If i go the DU-HA route, should i order weather tech mats for the fold flat under seat storage so it will all fit correctly?
pretty sure i sure that i want to bolt through the mat if thats how it installs!
I bought the DU-HA and I have the full weather tech. Drill a small hole an inch or so below the existing one and it works just fine. Even with the DU-HA and the mats the seats sit perfectly. No issues.
Also have Husky mats, and two car seats. Bought some Hefty 15qt bins at grocery store (16.79 W x 12 D x 6.6 H) and they work perfect. The height wedges them under the seats, with nothing protruding into floor, and they have never moved or shifted. Can fit three if need (I have two, plus sub).
Mine had the factory storage installed already (dealer included without charging). I like that it can collapse when needed. It's not completely flat, obviously, but has been useful on a couple of occasions when I needed the floor space.
I like mine, But my Big Dog hate's it !!
