If I knew you'd do it I'd leave a couple of bottles of pappy van winkle 23.
The grill really was easy-mode. The Cobb intercooler was easy except the cold side and knowing where to cut the feed. The winch mount alone may be 2 hours and is also easy. If you have a garage, I'll have time in January to come over for a weekend and we can knock it out.
Appreciate it greatly, they may be a bit before I can get everything in though, my father in law has moved in and we are in doing some remodeling to the house so that he is more comfortable, so mods have been stopped for now. But yes I have my garage and can use a buddies who has a lift in it.
How did you attach the honeycomb? I'm looking to do the same when I remove the intercooler slats in the stock location. I was thinking about making a little frame out of it and plastic epoxying it on.
Down low I used the fairlead to wedge it back and the tabs to wedge it forward.
For the main grill, I drilled a hole every other hex at the edge of the grill and ziptied the crap out of it. Maybe 30 zip ties. Anything the abs can withstand, the installation can withstand.
For the lower, I'll bet a raptor grill insert would fit (and look better)
Finally got her back from the shop!
Yeah, road angle and camera angle can do that
No took off all the tremor suspension
BDS lets you pick a 4" or 5" rear block. 4" gives you a little CS and the 5 gives you a little rake. What's your front and rear measurements from the center of the wheel to the top center of the fenders both front and back?
Got my AMB about a month ago and have done the following:
back wheel tubs
TuxMat (I like these more than the ford or the weatherTech. Have had both)
BakFlip G2 Tonneau (I like this, I have had rollup, clamshell and so on)
Short Antenna
BedRug Bedliner (I like this, I have had the spay in and drop in. If I haul something "nasty", I'm going to use a trailer)
Knob covers (why not? :))
F150led lights in the air slots
Didn't install as easy as they said but I like it, hooked to night lights
made my own "Tremor" mudflaps
Borrowed a friends table top CnC to do the cut in ABS and got $50 universal set of flaps :)
Made the door kickers (followed this site's postings :) )
Maybe after the new year, I'll put in some driving lights, backup lights, bed lights, under carriage lights to try to use up the aux switches :) Or whatever else I find in the threads that I HAVE TO HAVE! :)
Put on a Putco Ford badge. Debating on actually trying to sell the factory one since I keep reading they’re out of Blue/Black Ovals 😆
