I’ve done a few things on my 2025 Tremor 402a mostly F150leds I love my Tremor have any questions
Tow hooks finally came in. Took advantage of the Ford Black Friday code. Had seen quite a few complaints over packaging, and them arriving chipped to hell. Idk if I was lucky or they’re packaging better. They were wrapped really well, separately in both bubble wrap and corrugated thick paper.
Has anyone replaced just the center dash speaker with the B&O system, what did you use?
I did but I went far and beyond just replacing said center B&O speaker.
Looks like your shop foreman approves! Looks great.
What’s your full speaker setup? If you don’t mind sharing.
Here’s the breakdown.
Front Center channel****Always trying different speakers.
This is my current / third experiment with the center channel.
Illusion Audio C3CX
Front A Pillars
Focal TBM Utopia M Series 1” Tweeters
Focal 3.5WM Utopia M Series 3.5” Midrange
Front doors Mid Bass
Focal 8WM Utopia M Series
Rear Doors
Focal EC-165K Coaxial
Sub Bass / Current setup
Dual JL Audio 13TW5V2-4
Possible change to Dual JL Audio 12TW3-D4
Is it possible to disable auto/start stop? I saw one YouTuber disconnect a plug from his battery.
Yes, it’s possible and there are various ways / items that are available from the aftermarket that would accomplish this.
I’m not sure if disconnecting said wire applies to the current F150 but it did apply to the 13th generation F150.
If I remember correctly, the only drawback was that the SS light would constantly be on.
There's a connection near the battery that "may" work but this is not optimum as it will likely throw a code. I used the 4D tech and then FORSCAN to disable the dash light. No drama.
This is what I used. It was very easy to install and works great.
Seeing as how I’ve only had it 2 weeks, quite a bit.
Tinted front windows
Installed auto start/stop eliminator
Changed engine oil for first time
Dropped off at dealer to install spray in bedliner
Have hard rolling cover to install after bedliner
Ordered ditch lights
Ordered wiring harness for auxiliary switches
Ordered orange tow hooks with ford points
