Installed the interior Built Right Molle panels over the weekend, waiting on the Bedrug so I can install the bed molle panels.
How do you put like the Rac Attach? It’s on the pivot shortlist. Looking to hang a Velociracks off it.
I am not the original poster but I have a Kuat Pivot (same concept) and use it with a 4 bike OneUp usa rack. It is a game changer. Allows you to use your truck bed and tail gate without removing the bikes. You should definitely get one. I have a drivers side pivot because most camp grounds are on the right of the vehicle.
Agreed, it is a game changer for my usage of the truck. I went with the 1up and rakattach option as I wanted certainty of off-roading with 2 ebikes on the back. It does make the 1up rack stick out an addition 7" or so, but it's worth it in the long run. I too have the driver side pivot and I got the long version. It's like it was made for the F-150 tbh... the tire of the inner bike ends up about 6" from the side of the truck when it's swung open.
I have an ecoflow River Pro battery that I connect to Solar.
I'd like to charge it using AC but it kept pulling more than 400w and tripping the outlet in my bed.
Found that setting the ecoflow battery to "AC Slow Charging" mode caused it to never pull more than 200w on AC power, allowing me to charge it a bit faster than solar when driving.
Does anyone know how to put the actual temp gauge numbers (engine and trans) above the analog gauge?
Got my tremor just before Christmas.
Done a bunch of things to it but nothing nobody else has done.
This week I put on the the fox snap ring kit up front to help with rake. I have also done:
Stubby antenna
Wheel well liners
All weather mats
Tint
Ambient lighting
View attachment 15517Now I just need the damn vents to come in.
Where did you get your fox kit? The one I found said it wasn't recommended for the Tremor.
Installed the BedRug and finished installing the BuiltRight molle panels. Unable to install the small front side panels because of the tonneau cover.
It's really easy to notch them with a grinder, put some rust proof black paint on the cuts. Mine are notched because of my retrax cover brackets.
The tonneau is temporary until I can get an RSI Smartcap, if I have an issue with interference and cap I will trim the plates. Thanks for the recommendation. (y)
@SoMuchGood dude that's an incredible bummer. glad you're safe.
I always wanted to get the builtright stuff for my 15' platinum and never did. I'm going to have to change that with my 22' Tremor.
I got my spray in bedliner done, swapped my tonneau, bed mat and rack over to my tremor and tossesd on my rack stuff. Put husky floor liners in. It feels good to have my pre-post ride routine back to normal. I forgot how much getting ready for a ride out of my back seat sucked...
Next up is: rear wheel well liners and rokblokz mudflaps which are sitting in the garage ready for install this weekend. From there I'll turn to getting the baseline electrical stuff setup (added 5 fuse panel in the bed for switched/unswitched power and on-board air setup).
Looks like a X4S, I got my front BR panels to fit without any trimming. I'll get a picture later if I can remember.
