What will you connect to your Aux Switches?
I ordered S1s. Have not received yet. I believe they will look very similar to a Raptor and will mount between tow hook and exhaust. There is a torx bolt in the bumper that I hope is as simple and removing putting on the bracket and reinstalling.
Did you get these installed yet? Just curious how they turned out. TIA!
I have received them. I have not yet mounted them. I did play with them a bit, you could use that torx bolt I mentioned but they hang lower than I expected due to interference from the frame. I may ditch the bracket they sent and just drill a hole in the bottom of the bumper and mount them strait to it.
Okay I installed them today. I went ahead and drilled a hole in the bottom of the bumper between the tow hook and and exhaust. Added a bit of paint to cover any newly exposed steel to avoid rust. Then Bolted the S1s strait to that. That makes a nice tidy look that is less likely to get scrapped off from a bolder in the future. Wired them to Aux 1 for now. Plan to tie into the reverse circuit with a diode in the future. Pretty easy job really took me maybe 2 hours with drilling.
Thanks for sharing! I think this is the route I’m going to go.
Those are S2's. I put flush mounted S1's into the bumper on my Raptor. I went with the S1's for flush mount because almost same lumens, but you can use a hole saw instead of cutting a rectangle that the S2's require.
How are you running the wires for these? Are you using the Aux wires in the engine bay or cab?
I would love to install Diode Dynamic fog lights on the truck based on their beam spread and operating temperatures, however they don't yet have a mounting system for the Gen14 150's.
BD is waaayy ahead with the truck specific fitment kits.
I added some Diode Dynamics fogs to my winch install. I opted to keep the factory fogs. I think I did see a kit to swap out the factory fogs when I was going through their site and ordering lights for my truck.
https://www.diodedynamics.com/stage-series-fog-pocket-kit-for-2021-2022-ford-f-150.html
I plan on using them for;
LED Raptor grille light kit ( when I find one I like ) was told Orileys has a really good one from here for about $30
Possibly on/off for sub amp
