Hello everyone,
I'm new to the F-150 Tremor forum and could use some assistance. I searched the forum for this topic but wasn't able to find a definitive answer.
I have a 2026 F-150 Tremor and am installing the OPT7 Sidekick 86" Running Board Lights with sequential amber turn signals. I've attached the wiring diagram for reference.
My current plan is:
My original plan was to connect the left and right turn signal inputs to the corresponding left and right stop/turn circuits at the 7-way trailer connector. However, since those circuits are combined brake and turn signal outputs, I'm concerned the running board lights may also activate when the brakes are applied.
For those who have installed these lights on a 2024-2026 F-150 with LED taillights, where did you connect the left and right turn signal wires? If possible, could you share the wire colors and locations you used?
Any advice or installation tips would be greatly appreciated. Thanks in advance for your help
My current plan is:
- Tie the white wires together and connect them to the driver-side courtesy light wire.
- Connect the parking light wire to the parking light circuit at the 7-way trailer connector.
- Tie the black wires together and ground them to the chassis.
