17" wheels on a tremor
@Yeti what Eibachs are you running? I've had them on muscle cars in the past and really liked them. Did you change the shock as well, if so, what kind? Really thinking of going with the Roadmaster Active Suspension https://activesuspension.com/products/ford-f-150-pickup-4wd-2021-sd
If I did that would that change the spring and/or shock recommendation for the rear?
@marcus312 sorry for hijacking your thread. You've probably got your wheels by now, but yes, I really like 17" wheels for all the reasons already mentioned. That being said, I want to go with Method Bead Grip wheels and to get the offset I want, I need to go to 18" wheels. Planning on going with 35.3" tires (MT Baja Boss LT305/70R18) so I should still have plenty of sidewall.
The Pro truck coilover 2.0. The front coilovers "can" give you lift but if you drop the threads to 2" (effectively lowering it), you'll have maybe a 1/4" lift but the ride is definitely better. the rear shocks were their "up to 1.5" lift" shocks and they fit right in. I'm also going to give roadmaster a go. ordering this week.
